查看: 3051|回复: 0
迷信所谓统计分析的,请看:What Was That About Correlation & Causation?
发表于 2012-10-12 10:55:00 | 显示全部楼层 |阅读模式
Via Businessweek, we learn that Facebook caused the Greek Debt crisis, Global Warming is caused by NSF R&D budget, and other spurious correlations:
Need to prove something you already believe? Statistics are easy: All you need are two graphs and a leading question.
GMT+8, 2026-10-22 08:56 , Processed in 0.013224 second(s), 27 queries .
