楼主: 龙腾上海
精心收集奉献给大家-长期历史走势图表
 楼主| 发表于 2007-1-15 14:52:31 | 显示全部楼层
 楼主| 发表于 2007-1-15 14:53:15 | 显示全部楼层
发表于 2007-3-3 18:48:26 | 显示全部楼层
太好了 谢谢 谢谢
发表于 2007-3-3 20:00:31 | 显示全部楼层
真好!谢谢龙腾上海。
 楼主| 发表于 2007-4-3 11:13:42 | 显示全部楼层
GOLD
发表于 2007-6-22 08:57:52 | 显示全部楼层
好贴!!谢谢
 楼主| 发表于 2007-7-19 12:05:45 | 显示全部楼层
s&p500PE
 楼主| 发表于 2007-7-19 12:08:29 | 显示全部楼层
发表于 2007-7-27 17:16:42 | 显示全部楼层
非常谢谢
发表于 2007-7-28 14:50:39 | 显示全部楼层
好图,过瘾啊。。。
发表于 2007-12-4 10:26:52 | 显示全部楼层
谢谢斑竹
发表于 2007-12-5 08:22:22 | 显示全部楼层
很谢谢
发表于 2007-12-20 19:32:47 | 显示全部楼层
谢谢!!!
发表于 2008-1-17 11:41:31 | 显示全部楼层
非常感谢
发表于 2008-4-27 16:01:27 | 显示全部楼层
非常感謝!
发表于 2008-5-16 14:51:28 | 显示全部楼层
感谢前辈们的无私分享
发表于 2008-9-27 06:36:49 | 显示全部楼层
再补充个dow的长期图表
The inflation adjusted chart shows the true nature of the U.S. stock market.
Note the following about this chart:
- Dividends are excluded, so the chart only shows capital gains. The dividend yield of the S&P is running near 2%. (S&P data)
- The inflation rate used on the chart is the government CPI number until 1993. Beginning 1994, I have added 2.7% per year to the government CPI number. This should better reflect the true inflation rate since the government number has not been accurate since around 1993. The added 2.7% corrects the geometric weighting formula used by the government to calculate CPI. The government does other adjustments that constitute another 4% reduction in the inflation figure, but I will assume those adjustments are valid. For more information on inflation, see the following articles: http://www.shadowstats.com/article/56 , http://www.safehaven.com/article-8848.htm
On the chart, the long term trend line in green shows an average return of 1.9% per year. If you factor in the long term 15% capital gains tax, the return is even worse. Since capital gains tax is not adjusted for inflation, the average tax must be based on the 5.4% trend of the non inflation adjusted chart, so 15% of 5.4% is 0.8% tax. Therefore, your 1.9% return is reduced to 1.1% after taxes. The Wall Street shills do not want you to know that this meager amount of capital gains is all you should logically expect from a long term general stock market investment.
The Dow has historically moved within well defined channel. The boundaries of the channel have been touched only 4 times since 1910. The top of the channel was last touched in 2000.
They say "the market always goes up in the long term," but at an average return of 1.9% per year, it can take many years to recover from a large decline. The peak in 1929 was not ultimately exceeded until 1992. When the market touched the bottom of the channel in 1982, its value was about equal to the value at the beginning of the chart in 1910.
Most bubbles eventually correct back to where they began. The bubble that began in 1922 gave back all its gains by 1933, and the bull market that started in 1949 gave back almost everything by 1982. The bubble that ended in 2000 could easily correct back to its 1988 level of 4000. If you are optimistic, you might decide that the bubble began in 1995, and the Dow will only correct back to 7500. If you are pessimistic, the Dow could eventually hit the bottom of the channel at about 4000.
发表于 2010-3-15 08:30:26 | 显示全部楼层
谢谢!
发表于 2010-3-15 13:01:36 | 显示全部楼层
谢谢两位同学!
发表于 2010-3-15 21:05:56 | 显示全部楼层
确实是好东西,长期使用。
GMT+8, 2026-9-5 05:29 , Processed in 0.014255 second(s), 24 queries .
